Problem with accufab tb and plenum!!
RE: Problem with accufab tb and plenum!!
My car had the same problem, except it was surging. I didn't know what the screw on the TB did. After some adjustment it idles almost perfect..almost. My car is throwing a code about the TPS so, once I get that taken care of, I guess it will be okay.
Tried the battery deal, didnt help, but I did completly cover up the iac with so "cut it yourself gasket paper" and now i have no throttle hang and it idles a 600 rpm, when you give it gas and let off it goes down to 500 then back up to 600, i like the idle now but im sure ill throw a code for it. I am going to adjust the screw on the tb to give it another 100 rpm and i think ill be good. Covering up the iac cant be good tho...
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
