Wet Shot or Dry Shot?
I have decided to go with a 100 shot NX kit, and i am leaning more towards a wet shot because that is what i am seeign the most of. but was trying to get some imput if that is the best choice. what are the advantages of a wet shot what are the disadvantages?, and same with dry shot.
RE: Wet Shot or Dry Shot?
ORIGINAL: 04GunGT
nope havin been to the track yet [&:]
wet shot provides for better nos+fuel delivery if you plan to do more than 150 shot. if you're gonna stay below 150 shot, the dry kit will work just as well AND be a little safer (no fuel puddling issues)
ORIGINAL: mself52
i have also heard that wet is easier on the engine...so i to would like to know pro's cons.... so free up
Nitrous is nitrous once it enters the combustion chambers, so neither is any safer on the motor than the other.
Well, Code has more clout than I... but I would vote for the wet kit. Disadvantage? You can blow up your weak plastic intake manifold. You could do it with a dry kit too, but it's much more likely to happen with the wet kit if you're not careful. On the other side though, it's spraying the right mix of extra fuel with the nitrous so you don't need to worry about going lean for the first second of spray, or your injectors not being able to keep up.
