ENGINE CRANKS BUT WON’T RUN
RE: ENGINE CRANKS BUT WON’T RUN
When you say "cranks" are you saying the engine is turning over without actually starting? Depending on the year, it could be the crankshaft position sensor gone bad. If the engine actually starts and then dies then it's more than likely a fuel system issue.
apparently it was that little spring device in the fuel pressure valve core that caused the problem. the fuel was spraying from the pvc when I tried to hit the gas pedal while cranking the engine... bad juju!
MEISTERSNFB
03-31-2020 07:50 AM
bryan616fl
01-25-2019 09:07 PM
