18in rims... need programmer??
RE: 18in rims... need programmer??
You can do the math, and as long as it's a size that doesn't throw off the wheel and tire's aspect ratio (height), it won't change the speedo. But it only works for certain sizes; like mine are 275/35-18, which is right around stock give a couple millimeters. But if you change the final drive gear, you might have to get a new speedo gear, or a calibration.
He doesn't have a speedo gear, the only way to adjust the spedometer for tire size or gears is through a tuner. Here is a calculator for tiresizes: http://www.miata.net/garage/tirecalc.html
If you run a 275/30ZR18, then you would be only 0.1% off.
