Bullit brake upgrade?
I was reading an old 5.0 mag and they were saying this company offers a buillit brake uprade for 99-04 GTs for like 350 bucks or so. Would this be a worthwhile brake upgrade? Are the buillt brakes realy any better than a stock GTs?
RE: Bullit brake upgrade?
ORIGINAL: David_K
man you have a fast car. get the cobra R kit. brakes will be worth everypenny. they could be the decideing factor in stoppin an inch from a wall and going through the wall.
Here is the kit:
Bullitt front 13" brake kit, includes 2 Bullitt brake calipers with mounting brackets, front brake pad set, 2 brake hoses with banjo bolts and washers, and 2 Brembo brake rotors, perfect for 1994-04 Mustangs!, limited quantity, new...view
Is it worth it at all?
ORIGINAL: 2000GT4.6
Its 999 vs 399 though...
Here is the kit:
ORIGINAL: David_K
Here is the kit:
I don't think you can go wrong with that set up. I mean the GT brakes are sufficient, I guess it all depends on how quickly you want to stop
They're probably alright. I went with a Baer set up and it was nice. The car stopped on the dime. The only thing is if you go with slotted or cross drilled rotors, you hear them everytime you brake. But you won't have those issues with the Bullitts.
well yeah going up to a 13"
and what in the back? 11.5" ?
so yeah you should see a nice diff.
plus the Red Caliper with the horse looks so nice.
Where are they at for 399?!
please post the LINK...
THANKS
THANKS
ORIGINAL: JoeyD
THANKS
THANKS
Yes, it is worth it. I have them on my stang now. I guess it's about time to remove the "To be installed..." from my sig seeing as I now have them 100% installed
I did a write-up on the whole process, front and back. https://mustangforums.com/m_1112743/tm.htm
Stangsuspension has the full kits. http://www.stangsuspension.com/store...?idproduct=825
Ask them to swap the Cobra calipers with bullitt ones, they will probably be able to do that for you.
Edit: Front goes up to 13", rear goes up to 11.65"
09-25-2015 06:42 PM
mungodrums
Suspension
09-24-2015 10:12 PM
