Synthetic oil
RE: Synthetic oil
ORIGINAL: yellowcobra
5W-20 here Mobile one also and just to let you know once you go synthetic you can't go back so make sure thats exactly what you want to do, but i wouldn't know why you wouldn't.
RE: Synthetic oil
ORIGINAL: ackuric
the guy that said it doesnt make THAT much of a difference needs to be smacked.
it helps keep your engine cleaner, you'll have to change your oil half as much, so the cost of the oil pays for itself, and then some.
I gaurantee you if you go from regular oil to synthetic you will gain at least 1 hp
OOOOOOOOO yes i said it
lick it.
lick it.
RE: Synthetic oil
While you guys all argue aboout this, think about how much it costs to do an oil change yourself. $30 for a full synthetic change yourself. All you guys that think about this probably use premium gas in your stock car. How much more a year do you spend on premium gas compared to regular gas. And you wanna ***** about an extra $15 dollars 4 times a year to do a synthetic oil change. That an extra $5 a month you would have to save to use synthetic oil. Damn, thats a lot. You spend that on McDonalds in one lunch.
RE: Synthetic oil
ORIGINAL: Sonicpilz
What all is involved to switch your car to synthetic oil? Do you need to use a type of engine flush or something before you can fill up with synthetic? Also does synthetic oil make THAT much of a difference?
you take the bolt out of your oil pan let it drain, then take off your oil filter. Put a rim of oil around your oil filter, put it on, put the bolt back in your oil pan, and put new synthetic oil in....synthetic is much better in my mind...Castrol Syntex is actually my preference....
Sory bout the smart *** reply.....lol
RE: Synthetic oil
turbo stang is intelligent, he thinks it cost 4x as much. last time i checked a quart of regular oil is around 1.59-2.00, and synthetic is 3.59-4.00, thats for me at least, so yeah, 4x as much my ****.
RE: Synthetic oil
synthetic oil is not only a better lube for your motor, it also saves you one half of a weekend day every 6000 miles or so if you change it yourself. that right there is easily worth the extra whopping $15 or so per oil change.
RE: Synthetic oil
Try this site for some insight: http://www.royalpurple.com/techa/whyrpa.html Fact of the matter is, synthetic oil will keep your engine running like new almost indefinitely. No carbon in synthetic oil so no sludge or varnish build-ups of any kind. Better film strength, higher rpm's, higher HP (increase depends on what you are starting with), does not break down over time (ie storage), longer drain intervals, protects against high heat better, flows much better at sub zero temperatures, etc., etc. I've used it in one form or another in all my cars over the years and can not complain at all. About to go 100% synthetic with Royal Purple in crankcase, rearend and tranny. Here is on such test: http://www.royalpurple.com/hotrod1/hr1p1.html
Mobil 1 has always worked well in many of my cars. I decided to go recently with a premium synthetic (different base stocks), Royal Purple. Amsoil and Redline are two other such premium synthetics. Many others on the market, take your pick, they're all superior to conventional oils.
Other good reading:
http://www.royalpurple.com/arta/arta.html
http://www.amsoil.com/storefront/xlf.aspx
http://www.redlineoil.com/products_m...=1&subcatID=14
Other good reading:
RE: Synthetic oil
i just switched mine this past weekend and there is a very slight but noticalbe difference in the way the car starts, (mine doesnt take a couple of trys anymore) idles, and accelerates. all round it just runs better.
oh and it was $35 for the pureolater filter and 6 qrts of mobile 1 Extended Performance 5W30. the oil is supposed to last up to 15000 miles. so thats 4 oils changes you wouldnt normally have to do.
so say $15 for a regular oil change (the going rate at local oil change places around here) for 5 changes = $75
my oil change = $35
saved $40
my oil change = $35
saved $40
