Fuel Filter change?
RE: Fuel Filter change?
No, it is in front of the fuel tank, before the differential, not anywhere near the bumper. It is in plain sight and easy to access. You need a fuel line disconnect tool to change it. Check your manual for the change schedule. I am thinking 40k miles? I'm not sure, I'll check on that too if you need a picture.
ORIGINAL: DaMach04
oh oh oh....i got a question about Fuel Filter too...
Is there such thing as a better flowing filter? If so....does it help out with the power?
But they should be changed like every 15k miles or something NOT every 40k like someone said, if you wait that long you will have a good chance of starving the motor.
ORIGINAL: ForeverFord
Do I need a fuel line wrench to change mine fuel filter on a 04 GT?
btw hope you have the metal fittings, because those with the $4.97 tool make it way easier than the rubber connection.
I thank you very much!
ORIGINAL: Dave2000GT
The answer is simple look under the car where the fuel filter is, if the ends of the filter go into METAL fittings then the answer is YES, if they go into rubber fittings then the answer is NO.
