MASS AIR FLOW METERS??????????? - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Reload this Page >
Old 03-11-2006, 11:27 AM
stodenator
Default MASS AIR FLOW METERS???????????
i was just curious if anybody has changed their mass air flow sensor/meter? what kind of gains does it produce? i heard 42lb injectors must be used aswell? if you have any information, experiences i would appreciate the input.
jason
stodenator is offline
Old 03-11-2006, 11:58 AM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: MASS AIR FLOW METERS???????????
Unless you go FI, DO NOT waste your $$ on a new MAF. And 42# injectors on a N/A motor, you would probably watch fuel dump out of the tail pipes.
code3GT is offline
Old 03-11-2006, 12:05 PM
96cobra10101
+1. N/a you will be waisting fuel, plus you will need a bigger fuel pump for the injectors. Do those things if you get a blower.
96cobra10101 is offline
Old 03-11-2006, 10:08 PM
beheivjer
but if your maf is going bad and you want to you could use a cobra maf and #24 injectors if you want. I know i asked about this a couple of times on this forum and i just got the dont do it answer. YOu know what it wont hurt you to go to 24s just dont need to. if you are pussing alittle more air i say a little more fuel aint going to hurt either. rather be a little rich than lean
beheivjer is offline
Old 03-11-2006, 10:17 PM
amoosenamedhank
amoosenamedhank's Avatar
Yes but the mass air must match the injector size. Every mass air meter is calibrated to a certian size injector.
amoosenamedhank is offline
Old 03-11-2006, 10:18 PM
beheivjer
good thing a cobra maf is a #24 aint it then
Old 03-11-2006, 10:22 PM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: amoosenamedhank
Bad wording.....ANY MAF can be used with ANY injectors. The MAF isn't calibrated to the injectors, the computer is calibrated for the injectors and MAF. I run my stock MAF that came on my car with 19# injectors. I still use the same MAF with 30# injectors.
code3GT is offline
Old 03-11-2006, 10:29 PM
GSXRIntensity
Same here
GSXRIntensity is offline
Old 03-11-2006, 10:31 PM
beheivjer
yes but a recalibrated maf is easy to get and handheld tuner cost a considerable amount more at one time.in one way he is right . switching the maf will work but not the best way to go
Old 03-11-2006, 10:32 PM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: beheivjer
No matter how you word it, it's a bad idea.
code3GT is offline
Lethaldosage423
10-19-2015 12:12 AM
Dokilar
15
10-16-2015 08:13 PM
Dathan
10-05-2015 05:52 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Featured Sponsors
