MASS AIR FLOW METERS???????????
i was just curious if anybody has changed their mass air flow sensor/meter? what kind of gains does it produce? i heard 42lb injectors must be used aswell? if you have any information, experiences i would appreciate the input.
jason
jason
RE: MASS AIR FLOW METERS???????????
but if your maf is going bad and you want to you could use a cobra maf and #24 injectors if you want. I know i asked about this a couple of times on this forum and i just got the dont do it answer. YOu know what it wont hurt you to go to 24s just dont need to. if you are pussing alittle more air i say a little more fuel aint going to hurt either. rather be a little rich than lean
ORIGINAL: amoosenamedhank
Yes but the mass air must match the injector size. Every mass air meter is calibrated to a certian size injector.
yes but a recalibrated maf is easy to get and handheld tuner cost a considerable amount more at one time.in one way he is right . switching the maf will work but not the best way to go
ORIGINAL: beheivjer
No matter how you word it, it's a bad idea.
