lower control arms
RE: lower control arms
Not 100% sure, but I am also gettting some quotes on CA's and most of the quoters I received said they fit 94-04. Just find out what brand and specific model first to confirm, and then you can get a guarantee they will fit.
They should fit just fine. Every seller I have seen advertises from 94-04.. some say from 79-04.. which would make sense... we have pretty much the same rear end as the fox platform did.
Were they aftermarket control arms, or were they FROM a 98 cobra? If they were from the cobra.. not worth a dime. They have the same CA's as the GT.
VA, I just had the 03-04 Cobra control arms installed on my car and they are nice. I have Y2k Cobra R wheels on the car (9.5 inches wide) and 275/35-18 tires on the front. The rim used to hit the control arm when the steering wheel was hard over, but now they don't touch at all. It's a good upgrade if you ever think about going to a wider tire and you don't go with the MM K-Member and coil over package that requires a different lower control arm.
breaking
10-02-2015 01:27 PM
