99+ GT gear ratio (overdrive?)AUTO
OK...i know alot of topics ont his but i couldnt find one that asked this question....
on and Auto with stock gears and u take off overdrive the rpms go up cuz ur running with less gear i think 4 cuz 5th would be overdrive or it might be 4th is overdrive so u would be on 3. Anyway the rpms go up so with say 4.10' i saw the if you took overdrive off would it do the same and even go higher? or woul dit only be at a lower rpm then the general forum info said on a 5 speed in 4th gear.
basically would overdrive still make a diff???
RE: 99+ GT gear ratio (overdrive?)AUTO
^Yes Overdrive still makes a diff for me.
just like with stock gears in there.
but of course the rpms are higher at all times...
but yeah cruising with OD OFF- click it on and yeah the RPMS drop.
and of course cruising with OD ON - click it off and yeah the RPMS jump up.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
