zex wet nitrous kit!
#24
RE: zex wet nitrous kit!
ORIGINAL: code3GT
I always suggest the dry for stock engines, but some people think otherwise.
ORIGINAL: Wick001
I think you would have been fine going with the Dry Zex kit, Thats the one i'm buying tomorrow. Its easier to install, dont have to worry about fuel puddling and safter for N/A engines. You really dont need a wet kit unless you already have a supercharger or turbo, so it can burn more fuel in the chamber because of the F/I... I always though wet kits were for higher HP applications.
anything over 100 shot requires you to retard timing
Why is that? wont you run rich then every time u arent spraying?
#25
ORIGINAL: code3GT
Huh?
It will only show bottle pressure, not contents in the bottle.
ORIGINAL: Wick001
It's nice to know how much nitrous you have in the tank
I never owned nos so i'm curious also.
#26
ORIGINAL: SpecterGT260
ORIGINAL: code3GT
ORIGINAL: Wick001
#27
ORIGINAL: ZW99GT
No you rely on the computer to decifer how much oxygen(or nitrous) is coming in. The computer compesates for the extra oxygen and therefore spray more fuel. Its as easy as that.
ORIGINAL: code3GT
ORIGINAL: Wick001
#28
Hey, since we are all here and nobody is posting on my other thread about this kit. Im having a problem with mine. It wont open up (I think the active fuel control system is keeping it closed). Im getting my fuel from the access port on the fuel rail. Im thinking maybe there is some air in there since it would really have nowhere to go. So, do you guys think thats possible? Will I have to bleed the line from the fuel rail to the solenoid/NMU?
jwog666
12-27-2021 08:09 PM
