zex wet nitrous kit!
my mods right now are 4.10 gears, bbk longtube headers, bbk o/r x pipe, bbk 75mm throttle body, 75mm c&l plenum, weld in slowmaster mufflers!!!!.......i have just ordered a zex wet kit, should have it tuesday or wednesday...what i need to know is what all do i need to run the kit safe as possible? i also ordered a msd digital window switch and i have ngk tr6 spark plugs already!! is there any other safety stuff i need? and what do u all think i could run a 1/4 mile with 75 shot and then with 100 shot and then 125 shot......thanks in advanced!
RE: zex wet nitrous kit!
ORIGINAL: PerformanceRed4.6
I think you would have been fine going with the Dry Zex kit, Thats the one i'm buying tomorrow. Its easier to install, dont have to worry about fuel puddling and safter for N/A engines. You really dont need a wet kit unless you already have a supercharger or turbo, so it can burn more fuel in the chamber because of the F/I... I always though wet kits were for higher HP applications.
anything over 100 shot requires you to retard timing
ORIGINAL: Wick001
I always suggest the dry for stock engines, but some people think otherwise.
