What could this be??
03-12-2006, 10:10 PM
I was just coming home tonight, and i was pulling in to the turning lane to my apartment. All of a sudden the engine turned off. I have a 03GT with 63,xxx miles. I bought it laster February and had absolutely no problems with it so far. I was driving the car normally, nothing crazy. I am thinking fuel injectors. Anybody have any ideas?
03-12-2006, 10:12 PM
RE: What could this be??
sounds like the infamous IAC, more details please
03-12-2006, 10:13 PM
more info. would it restart? checked your battery? fuel filter or pump? car throw any codes?
Super Moderator
Don't even consider fuel injectors yet.
Start with the simple, obvious stuff. It's usually something simple.
Sounds like an IAC like Brute said.
03-12-2006, 10:15 PM
It restarted right away, no codes, although i wasn't looking carefully-i was rolling into incoming traffic. Popped the hood, battery lloked fine, all the gauges in the instrument cluster were fine after i restarted.
03-12-2006, 10:27 PM
If it is the IAC, will this happen again soon? (question for those who has had this happen before) I plan on cleaning it tomorrow after work.
03-12-2006, 10:42 PM
chances are it might, try to keep the throttle open just a bit if if you're stopped in traffic
03-13-2006, 12:15 AM
Yeah, i'm not too worried about it when i am stopped, more along the lines of when i let off the gas while cruising....
03-13-2006, 05:36 PM
Well, i have the carb cleaner. I went to take out the screws and they are so tight that i started to strip them. I'll try puting WD40 on there to loosen them up. If that doesn't work, think a ford dealership would loosen them up for me?
03-13-2006, 05:38 PM
im not putting this together today. call me a noob but IAC stands for.....
