1997 mustang gt with mods
hi i have a 1997 mustang gt. it is a five speed. with rebuilt trans 2000 miles ago. brand new borg warner clutch. with out anything except k n filter i ran a 15.13@91 but since then i put 2 chamber delta flow mufflers. flowtech off road x pipe with mil eliminators. underdrive pulleys. cold air intake. steeda triax short shifter and 3.73 gears. what do think i will be running now. since stock was 15.13@91 do u think i could hit 13's thanks ricky
RE: 1997 mustang gt with mods
ORIGINAL: quarterhorse
K&N: May give you 3 more horses. Good for .2sec off your time
Chambered mufflers: Good for 5-7hp
O/R x-pipe: about 10hp
CAI: worthless...should have been a M.A.F. Maybe 5 horses if ur lucky.
Tri-ax: great mod, good for making sure you don't miss 3rd. May can get a better time w/this if you screw up lot w/the stock shifter.
Underdrive Pulleys: 10-15...say 12hp to be safe. March Performance, & Steeda are the brands I say stick w/it for these.
These are mods will cut your time, but you're best mods IMO have been your gear, shifter, pulleys, & o/r x-pipe. You want 13's, get a m.a.m., straight through exhaust, 4.10's, DR's & then holla back!
you'll need a little more than that to hit 13.5. your best bet is a PI head swap. that's the best mod for stock 96-98 GT engines. with the mods you have done, you should be in the low 14's.
I agree with GSXR. Good explaination dude!
Also I read about using a 75mm TB earlier on your stang. For your year, I wouldn't do it because that will hurt you, not help. Stick to the 70mm. Port and polish...priceless.
