Cutting springs
Old 03-19-2006, 12:30 AM
dlazrael
dlazrael's Avatar
Default Cutting springs
At the moment, I am saving for the eibach sportlines and C/C plates, a friend suggested cutting springs, how/where should they be cut, and is this dangerous? can it cause the spring to weaken so much that it will damage the suspension? I'm wondering if I should wait 8 more months, or do it now... thanks
dlazrael is offline
Old 03-19-2006, 12:32 AM
JonBeast
Moderator
JonBeast's Avatar
Default RE: Cutting springs
Do Mach's have prog. rated springs like the cobras?
If so, then it is safe to cut a coil off or so, since it won't change the spring rate.
JonBeast is offline
Old 03-19-2006, 12:34 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: dlazrael
Its a bad idea, the car will handle and ride like ****.
2000GT4.6 is offline
Old 03-19-2006, 12:37 AM
dlazrael
dlazrael's Avatar
600 lb Helical coil, rubber-insulated, unique linear rate (front)
250 lb Helical coil, rubber-insulated; unique linear rate (rear)
Dunno if that tells you if they are similiar to the Cobra's
dlazrael is offline
Old 03-19-2006, 12:41 AM
nathansmith50
nathansmith50's Avatar
don't cut them.
save that for camaros. it's redneck and it sucks because your car will ride for ****.....
nathansmith50 is offline
Old 03-19-2006, 12:42 AM
dlazrael
dlazrael's Avatar
Very well then, now if someone buys my rims (stock GT) i have on ebay, I can get some springs :-p
dlazrael is offline
Old 03-19-2006, 12:43 AM
JonBeast
Moderator
JonBeast's Avatar
Yea, you might as well just buy some springs. They aren't very expensive, and they won't give you any problems
JonBeast is offline
Old 03-19-2006, 12:45 AM
2000GT4.6
2000GT4.6's Avatar
what rims and where is the link
Old 03-19-2006, 12:47 AM
dlazrael
dlazrael's Avatar
Same ones you got.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
dlazrael is offline
Old 03-19-2006, 12:52 AM
SOHCtimes2
SOHCtimes2's Avatar
Cutting springs is for ricers....lol
SOHCtimes2 is offline
Quick Reply: Cutting springs
