Clutch Cable Replacement?
RE: Clutch Cable Replacement?
I did a '94, similar setup. First step, I removed the drivers seat. If you area big guy like me, it helps you get your head/neck up easier under the dash. remove the cable end on the clutch fork first, I just pushed the fork forward and slipped the cable end off. I think there may be a bracket on the LS frame to unscrew about where the battery is. Crawl under the dash and pop out the cable end from Quadrant, pull the cable out from firewall and remove from car. Reverse procedure on install.
John
John
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
