http://secure-order-area.net/paulshp...=8263417_10767
This one will work well for you. If you do not like this one then Hurst makes a kit called "roll control" This will also work for you. It can be purchased thru "Jegs" or "Summit".
A line lock locks up the front brakes only so that you can do a burn out easyer. If you have big brakes in the back a line lock is a good idea. Basicaly you push in the break pedal, flip the lock switch, do a burn out at will, and then deactivate the lock to roll off the line.
