Spark Plugs
RE: Spark Plugs
Here it is:
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
RE: Spark Plugs
I changed my ignition wires with Ford Racing 9mm red. Very good wires and each individual wire has the Ford Racing logo and the cylinder number on it (1-8). No rocket science there. I am about to install these new tech plugs as they have gotten some very good results with them in Mustangs.
http://www.e3sparkplugs.com/
By the way, the best price I have found these plugs to date is at Advance Auto Parts @ $6.99 each. WC Whitney carries them at $8.99 each. Iridium type plugs typically go for $11.95 to $14.95 each so the E3 price really isn't that bad at all. They also have a 100,000 mile/5 year warranty on them.
RE: Spark Plugs
ORIGINAL: Emann0007
Here it is:
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
Here it is:
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
AWESOME INFO. Damn it, just cleaned up the sticky area. Oh well.
RE: Spark Plugs
They are pregapped. I just got done installing my tr55ixs. Man that passenger side is a bitch. The closest spark plug to the firewall on the pass. side didnt want to come out, and then the coil didnt want to go back in. Ended up taking more than an hour, but oh well. I took out the CAI to have a little easier access.
RE: Spark Plugs
ORIGINAL: code3GT
Depends. I run mine just a shade tight.
ORIGINAL: rbstang
do u have to gap the ngk tr55? my dad said they come pre-gapped and you shouldnt have to re gap em.
RE: Spark Plugs
ORIGINAL: rbstang
well im probably going to be running my hypertech chip again and it advances the the timing to the max. so.. what gap would be good for increased timing? because i dont want to get pinging like i did last time on the dyno.
ORIGINAL: code3GT
ORIGINAL: rbstang
RE: Spark Plugs
ORIGINAL: code3GT
ORIGINAL: Emann0007
Here it is:
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
Here it is:
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
