Rear wheel drive
Old 03-24-2006, 02:05 PM
06mustang88
06mustang88's Avatar
Default RE: Rear wheel drive
there's an sn95 stang on cardomain that's on a bronco frame all jacked up with huge tires. laughed my *** off first time i saw it
06mustang88 is offline
Old 03-24-2006, 02:10 PM
monkeydude3
monkeydude3's Avatar
lol... that's one of those things you do simply because you can and you don't ask questions. I certainly hope the guy didn't kill a GT for that
monkeydude3 is offline
Old 04-04-2006, 11:57 PM
zack1122
zack1122's Avatar
Default Rear wheel drive
Actually, I meant the limited slip diff. Someone told me until 94, mustangs had 7.5 diff, which he said one wheel would spin then the other would start spinning after the first one did. He said after 94, they had an 8.8, which meant both wheels would spin at the same time. Can anyone comment or clairify???? Thanx
zack1122 is offline
Old 04-05-2006, 12:06 AM
VARifleman
VARifleman's Avatar
ORIGINAL: zack1122
That's the size of the rear end, not whether it has limited slip or not. Limited slip is between the one wheel peel cars that you're talking about and detroit locker (mechanically locking differential) cars. The limited slip has a system of clutch disks inside of it to make sure that if you're accelerating in a strait line the rear wheels are spinning at the same speed and you don't have the concern of losing traction in a sharp turn due to a locking diff.
VARifleman is offline
Old 04-05-2006, 11:27 PM
zack1122
zack1122's Avatar
Thanks for the info. So what type of diff does my '99 GT have? It's stock with the stock 5 speed t-45. Does that mean that both my rear wheels spin at the same time during acceleration??
zack1122 is offline
Old 04-06-2006, 12:07 AM
ByPopularDemand
ByPopularDemand's Avatar
Yes both of your tires spin. You have the lsd
ByPopularDemand is offline
Old 04-06-2006, 12:38 AM
ShadowDrake
ShadowDrake's Avatar
ORIGINAL: zack1122
8.8" rear with ford's trac-lock (read: limited slip) differential.
Both wheels -should- spin... maybe not at the same speed but very close, both wheels are getting power.
ShadowDrake is offline
Old 04-06-2006, 12:54 AM
ghoste
ghoste's Avatar
Found that out trying to turn my wheel for my driveshaft to turn so I could get to the upper top bolts to loosen, both wheels turn! LSD!
ghoste is offline
drfister
05-03-2018 10:38 PM
spectreman
03-31-2016 09:26 PM
JonnyBlazeGT
11-03-2015 01:10 AM
ccwebb
08-11-2015 06:47 PM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: Rear wheel drive
