New gauges installed
RE: New gauges installed
ORIGINAL: 03sonicgt
Those look really good. Code what did you pay for the gauge cluster?
ORIGINAL: Tac2cul
how did u hook up the oil pressure and water temp? Did u connect the oil using the #8 oring plug next to the oil filter?
Where did u tap in for the water?
they electrical or mechanical?
they should look nice wit your setup
There is an allen wrench plug in the side of the block for the oil, my stock gauge still works. But with the water, I can't reach the plug because of the long tubes. I had to tap in where the stock sensor is (on the intake). I am gonna put the car on a lift and see if I can reach the plug on the block for the water so that both the stock and autometer gauges work.
ORIGINAL: code3GT
It's PIMPIN', huh?
ORIGINAL: 2000GT4.6
Dammit I hate you for having that lunar gauge replacement dash cluster..
I am kinda disapointed in autometer so far though. 225 or something bucks for a fuel pressure gauge and they dont send ya the adapter for the sensor to the fuel rail??? And whats with having to drill holes to intsall the full pillar pod onto the stocker?? (i got double sided tape today to try).
