24lb with PI Install
I'm waiting on my 24lb injectors to come in. I paid 155 for them ( Motorsport brand ). A ford tech told me I would see better rewards putting them in instead of the original 19lb with my PI install when that goes in, in a week or so. I don't know too much about injectors. I'm assuming these will help me to not run lean, like i sorta am now with my intake and exhaust mods. Can you guys tell me about injectors and stuff, like the gains and things that are given and things of that nature.
RE: 24lb with PI Install
This is just my opinion, so take it with a grain of salt. When it comes to the stock injectors, they can handle alot of performance add ons. When you start adding non N/A parts, is when you need to start changing your injectors. For the mods you are getting done, the stock injectors will work fine for you. You just might need to have a Dyno tune done to your car and have a chip burnt for it. Good luck with your project.
You're not going to see any gains with larger injectors. The best way to tell if you actually need those larger injectors is to get a tune. Then the tuner will be able to tell you if you need them or not.
09-10-2015 08:39 PM
