04' GT 5spd - Transmission question
Code3GT (I hope I don't get chewed up for asking) :-)
I did a search on this forum for transmission and I did not another thread with my problem.
Here it is: my '04 GT 5spd shifts OK on all gears execpt 2nd (no grinding), just the car bugs down and jumps a little.
It doesn't matter how I release the clutch, or how I accelerate, it always jumps?
I have not clue what is going on. I let my buddy drive it (he has a 2000 GT 5spd) and he noticed it right of way.
Does anyone know what it may be? I had taken the car to the dealer and they said it was fine?
Thanks,
Thanks,
RE: 04' GT 5spd - Transmission question
your friend noticed it right away but the dealer didnt say/do anything? thats stupid...take it back. lol. check the tsb section too for something possibly relating to that..never know what you can find in there. my tsb ended up getting me a whole new transmission.
the clutch cable might be a little loose and need to get use to your driving. the last driver probably drove like crap and the car was use to it. give it a week and then if nothing changes take it to a transmission shop. your buddy has a 2000 and you have the tremec so your clutches are also VERY different. your clutch is a lot more touchy.
it could be that but i dont see that happening sooo soon on an 04 gt. it is barely a year and a half old. i say give it a week get the car to get use to you and then go from there
You'd hear a synchro problem.
Is your clutch slipping? Put it in 3rd gear and hit the gas, if it rev's up without accellerating to match the RPM's.......you need a clutch!
Is there slack in your clutch pedal?
ORIGINAL: Dan04COBRA
I will check the clutch tonight. I have had the car since DEC'05. Right now there is no slack on the clutch pedal.
Also, what is the "tsb" that Car_Ramrod mentioned?
There is no slack on the clutch pedal?
I did take a look at the TSB. There are a few about manual trans. I guess that I will take it to a transmission shop and see what they say.[X(]
AmericanMuscle4.6GT
11-10-2015 02:06 PM
LivingInThePast
09-16-2015 12:20 PM
