Question,about braking.
Old 03-30-2006, 05:30 AM
St4ng07
St4ng07's Avatar
Default Question,about braking.
Ok after driving my car for a good amount of time today? As soon as I hit 30mph while braking my car starts shaking. Not bad but very annoying. All the brakes and rotors are fine. Could it be my alignment or just some bad ball joints?
St4ng07 is offline
Old 03-30-2006, 09:07 AM
DIVER8374
DIVER8374's Avatar
Default RE: Question,about braking.
Sound to me like you might have a wraped rotor. It might not be noticable to the eye, But if your car only shakes when you hit the brakes that is what I would think it is.
DIVER8374 is offline
Old 03-30-2006, 09:45 AM
yoteehunter
yoteehunter's Avatar
^+1
Next time you have your wheels off make shure they (shop people), or you dont put them on with an impact wrech, tell them to use a torque wrench. To stop the problem you will either have to turn your rotors on a mill or buy new ones and new pads as well. Or you can just have the vibration, and wear out your current pads, but if you do that they wont be reusable.
yoteehunter is offline
Old 03-30-2006, 10:44 AM
70 MACH I
70 MACH I's Avatar
+1, turn your rotors, that DRIVES ME CRAZY! My wife is the only person I know that can warp the rotors in a POLICE CRUISER in 6,000 miles! When I bought her the retired Crown Vic cop car I thought my rotor problems were over. My cop friends laughed, even they never warped a set!
John
70 MACH I is offline
Old 03-30-2006, 11:15 AM
GTkyle
GTkyle's Avatar
+1 Take them to a machine shop to get them resurfaced...or if you have a buddy with a lathe give him the rotors and a 12 pack.
GTkyle is offline
Old 03-30-2006, 12:20 PM
S281SC
S281SC's Avatar
I'd try one thing before deciding to turn the rotors.
Loosen all lugnuts 1 turn, then retorque USING A TORQUEWRENCH, following the "star pattern" in 3 seperate steps...
Torque all to 60 ft-lbs,
Torque all to 75 ft-lbs,
Final torque all to 85 ft-lbs.
I've had several cars that I have "fixed" by using correct, even torque. Just one example - My father-in-law recently had new tires put on, and they tried to pressure him into replacing brakes that he knew were only 3 months old. When he got the truck back, it vibrated horribly while braking. Of course, it wasn't their fault - "We told you it needed brakes". When I checked the lugs, they were anywhere from 70-160 ft-lbs of torque on the same wheel... A good re-torque solved that issue. Some of the impact gun jockeys tend to go a little crazy. [:@]
S281SC is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Question,about braking.
