stall converter
stall converter
I've done a few mods to my 04' GT, but my brother-inlaw says that i need to change out the stall converter. I've installed under-drive pullies, a 75mm throttle body, changed the rear-end to a 3.73:1 I've had the commputer reset by a tuner guy in my local area. so all that's good. I'm just not sure what size stall to put on it. I would like to replace it before i install the new supercharger. thank's you guys.
RE: stall converter
yeah it's an automatic. i bought it from my sister who has a problem with her feet so she is unable to drive a manual. how do you go about determining what size stall to put on your car? my cousin said he has a 4500 on his but his car has a 351w in it. I need the car to perform well on the highway, but i also need to have the horses there if someone decides to test my car's performance.
[IMG]local://upfiles/33531/DB911392869149E2986A435EF0CCA484.jpg[/IMG]
RE: stall converter
ORIGINAL: justroge8
RE: stall converter
ORIGINAL: XxphantomsnypzxX
I just figure a 3k stall is mild, not too harsh, a tranny cooler is a really good idea if your gonna be using the torque convertor regularly.
