REVVING ENGINE
REVVING ENGINE
My 4.6 sohc (96) has recently came up with a little problem. Sometimes when I pull up to a stop my engine will not come down from 1500 rpm's, even when I am on the clutch. It also seems as if I step (hard) on the brake it will cause the idle to lower, other times this problem is non existant. WHAT IS MY PROBLEM????? It is driving me up a wall. I think it could be a vacume leak, but I dont know where from. And I cant hear it sucking. Another thing is my ABS light comes on once in a while, could these two be related such as in a brake booster? Just a thought. Thanks for any help.
RE: REVVING ENGINE
ORIGINAL: koumiss45
OK 2nd thing is normal. When you step on the brake hard your rpm will lower because your drawing power from the motor.
OK 3rd thing your probably low on brake fluid or your abs sensors are damage.
Thats my guess.
RE: REVVING ENGINE
Thanks... could you tell me where exactly the IAC is located on this motor, 2nd, Yeah I am a dumbass that is so true, 3rd, Its on level now since I've had it, but I am not sure about the previous owner. Appreciate the help.
RE: REVVING ENGINE
First thing, what will you sell me one for( shipped to missouri) 2nd thing is I've heard that it will improve it for a while but then it will go out. Thanks, I'm not ?'ing you expertise here just asking for clarification. You obviously know more than me on this subject.
