S-Connector
S-Connector
On my brake pedal there is connector with 2 wires coming from it, one of the wires broke off and its just hanging there.
That one wires prevents the brake lights from coming on, and prevents shift from part
Does know the ford part number of that connector? Would it be best to probably solder the connection back?
RE: S-Connector
so you have two pieces of wire hanging? You can either A) strip both ends and use a wirenut if you are in a bind,
or B) put a piece of heat shrink on, solder the wires together, then heat u pthe heat shrink
