Clear Fog Lights
Clear Fog Lights
Just finished installing a set of clear fog lights. I need to replace the drivers side because it was damaged and decided to go with these.
The look nice, install took less then 30mins. Had to do it by feel because everything is tucked away but not to hard. I don't have any night pics yet (not dark yet) and I am waiting for my bulbs to come in which should be early this coming week.
Here are some pics
Partial Stock:
Partial Clears:
Full Stock:
Full Clears
Here are some pics
Partial Stock:
Partial Clears:
Full Stock:
Full Clears
RE: Clear Fog Lights
awesome...can you maybe give a quick write up about the install. like where the screws are/how many of them there are. it would be greatly appreciated. thanks in advance if you have the time!
they look 100 times better. a worthy investment. congrats.
Well done! I got the same clear foggers but haven't put them in yet. Did you get the Luminics bulbs as well? I got the pure blue ones and am eager to see how well they work.
Was the install tricky at all? It seems pretty straight forward.
Quick Write up.
Get the front end up off the ground and supported with jack stands.
You will need a 7mm socket and atleast 9" of extension.
There is one screw coming in from the bottom of the bumper and there are two more on top.
The two on the top will have to be done by feel. You can but one hand up behind the fog light and the other in from in front of the radiator (there is a splash guard that just move out of the way)
Pull the top two out.
Disconnect the light and pull it out.
Swap the screw spring clip on the stock fog light to the new fog light (the one from the bumper screw) and install the new bulb
Put the new light in and install the lower screw loose.
The fun part is next you will need to guide the top screws up into there holes and then get them lined up with the holes in the bumper. Not as hard as it seems.
Tighten the top 2 screws.
Tighten the bottom screw.
Reconnect the wire harness.
Looking from the front of the bumper at the fog light towards the center of the car you will see an adjustment screw. I adjusted the light until it fit the bumper correctly and your done.
I used my air rachets and it made life alot easier, but there is plenty of room to use a standard rachet.
I got Silverstars. I have them in for my headlights. There ehh, but still better then stock.
ORIGINAL: wixx_00GT
