Ford Focus fuel pump?
I've seen a few people on here with the Ford Focus fuel pump listed as a mod. Is there a difference between the mustang and the focus fuel pump? Whats the advantage from the focus pump? Also whats involved in installation? Do you have to drop the gas tank?
RE: Ford Focus fuel pump?
ORIGINAL: Sonicpilz
correct.
It does outflow the stock pumps by quite a bit though, and the install isnt that bad at all. I did mine with a friend in about an hour and a half. if you ever get a large (75+) nitrous shot, s/c or heads and cams i'd definetly get one though.
To be honest I was thinking of mach 1s with H/C/I because the are putting between 370-400 at the wheels, A GT i'm not sure. I know one thing though it def wouldn't hurt anything! The real tell tale will be you dyno sheets and a/f. If you start to lean out in the upper rpms I would definetly suggest it. It won't give you any more power- its just an extra safety precaution to avoid leaning out and detonating.
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
jpplaw
08-22-2015 09:29 PM
