non pi cams question
RE: non pi cams question
I have always wonderd this myself. Im fixing to order the 274h's for my non pi. I will tell you that when I called comp cams I asked them what would happen if the non pi cams were run on pi heads and here is exactly what they said. "Pi cams were designed for pi heads and non pi for non pi heads" Then I asked them why excatly it wouldnt work and they had no answer wich tells me that it would probly be fine, however a pi cam on a non pi head can cause problems if the lift is more than .540. I think if you were to run them on the pi heads they would just make more power than on a non pi but im just guessing.
well lift isnt a problem-they're rated at .500/.500-and i know back in sept 04 issue of mmff, they tested all 6 comp cams in a 4.6 with i think patriot 4.6 heads-so they should work-im just wondering if anyone else has experience or knowledge about them...
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
