351W swap into 96-98
Old 04-05-2006, 01:17 PM
lucheski
lucheski's Avatar
Default 351W swap into 96-98
I am looking at getting a 96 V6 mustang and swapping in a EFI 351W-T5 combo
Where I can find info performing this swap...
For starters I know I need the k-member and maybe some custom headers.
lucheski is offline
Old 04-05-2006, 03:03 PM
uberstang1
Chupacabra
uberstang1's Avatar
Default RE: 351W swap into 96-98
thats one hell of a swap
uberstang1 is offline
Old 04-05-2006, 03:07 PM
GodAmGT00
GodAmGT00's Avatar
Well, there's the long answer, and the short...
In short, you'd need a lot, but it's well worth it if you ask me.. If you have the money, it's even more worthwile..
The long, hell, I don't know.... I'm sure there've been many people who've done this swap.. Have you checked online?? How about on this site??
Wiring harness, suspension upgrade, driveshaft, engine/tranny mounts will need to be fabbed up... There would be other things that come up.. It's most likely a completely Custom job....
JT
GodAmGT00 is offline
Old 04-05-2006, 05:16 PM
Acer2428
Site Mod
Acer2428's Avatar
Check out the 351 section under 'special stangs'
Acer2428 is offline
Old 04-05-2006, 07:47 PM
w8less
w8less's Avatar
u would need a lot but the motor mounts for a 302 will work for a 351, u need a read end a t5 barely holds a 302 i would not recommend using it with a 351 cause the torque from it will rip it apart. ummm...........kmember like some one said u can buy the drive shaft and headers for the fit but more than likely the wiring will be more a hassle then the acutal install. also trickflow edelbrock and someone else i can't remember right of hand make efi intakes for a 351 also u would need at least 24lbs injectors to feed the beast. but if u have the money its definately worth it if ur seeking some easy power.
w8less is offline
Old 04-05-2006, 08:03 PM
yoteehunter
yoteehunter's Avatar
I would think that a wiring harnes from a 94-95 would work. The computer is for a 302 but I think it could be reburned as well. I think that would be your best bet. I have a 351 that runs, but its carbarated and I wanted to make it FI and swap like you. Good luck!
yoteehunter is offline
Old 04-05-2006, 08:58 PM
w8less
w8less's Avatar
thats the last computer i would get those things hate cam swaps if u were to do that i would get one out of a 87-93 computer the settings are a little bit better for performance
w8less is offline
Old 04-05-2006, 09:24 PM
Twister
Twister's Avatar
It is against federal law to swap a 351 into that car
Twister is offline
Old 04-05-2006, 09:45 PM
Acer2428
Site Mod
Acer2428's Avatar
True.
You could swap a 4.6 in it though and re-register it as a GT.
Acer2428 is offline
Old 04-05-2006, 09:59 PM
jmmorgan82
jmmorgan82's Avatar
isnt it against the law to run an off-road mid pipe too??? if so, prob more than half the people here are violating the law
jmmorgan82 is offline
Quick Reply: 351W swap into 96-98
