correct me if im wrong?
RE: correct me if im wrong?
ORIGINAL: GSXRIntensity
If you can install it you will get much more than 10hp and you redline past 6000rpm. I got around 25hp from it and my redline is 6700rpms with my powering peaking at 6100. My head/cam/intake install netted me a 70rwhp gain. However, if your car is basically stock I'd not jump after the P-51 right away. And yes...like a Vortech. That's all that'll fit really. BTW...I've a stock bottom end.
ORIGINAL: dvs_03gt
ok say if u are familiar with the p51 intake manifold answer this for me..
if u install it, it gives u 10+ hp, and you can reach a 6000 rpm redline.
with it installed you cant use a twin screw s/c, but u could use a centrifrugal like a vortech?
if you cant use if with a s/c why is it good?
would this be a good mod?
ORIGINAL: IWinULose
I find that hard to believe. I am guessin you were full bolt on before you put heads, cams and the intake on. So, full bolt on GT is say 280rwhp, plus 70rwhp for your setup there, and that puts you at 350rwhp N/A........
ORIGINAL: dvs_03gt
ORIGINAL: gt96stang
Show me a full bolt-on gt that made that much hp....
ORIGINAL: IWinULose
ORIGINAL: dvs_03gt
ORIGINAL: IWinULose
Add up the fiugres. Take a stock GT, at 220rwhp. You need 60 to get to 280rwhp. Full exhaust including LTs, a good tune, CAI, TB and Plenum, all the normal bolt ons and i bet you are darn close to 280RWHP.
Not close to 280, maybe around 265-270
ORIGINAL: IWinULose
ORIGINAL: code3GT
Matt's 95 Stang
10-05-2015 07:16 AM
