pro-kit or sporline
RE: pro-kit or sporline
If you can't decide on a particular height and you can spring for the extra dollars, go with coilover kits. That way you can adjust the height to whatever you want or suits your fancy. You can set the car exactly how you want it to look. I have noticed that coilover kits for mustangs are not that expensive (about 200 a pair) which is not too bad compared to imports and other cars. I've seen alot of kits in MM&FF and 5.0 from the major advertisers. You should check it out before you commit. It's always an option.
Thats the part that I dont understand...I am trying to decide between the pro and sport line kit from eibach. I AM going to buy the kit which includes shocks/struts but I wasnt planning on buying the anti-roll bar kit until later.
1 should I buy the anti-roll bars now? or later?
2 I measured my height and I have 4" above each tire to the fender so 2" actually doesnt seem like that much of a drop...opinions?
3. do I have to buy the c&c kit with either setup and if so why?
thanks guys
"G"
thanks guys
"G"
