Will the cobra s/c bolt on to the 2v motor?
RE: Will the cobra s/c bolt on to the 2v motor?
no it wond because of the lower intake wanting 4 valves. if you want a cobra sc just get a kenne bell, or an after market vortec that can handle more psi. why would you want a stock sc??
well with a mach the sc will fit. basically all a mach has is a cobra engine not built by svt. it was built by ford. all you need to do is change the ram air and the mounts and it will fit
man, if it did fit the 2v, you wouldnt be able to swing a dead ca w/o hitting a blown 2v, i know i would jump. but until i can afford a kb or another s/c, i will just be valve-impared.
