Have a 4R70W/AODE? Read!
RE: Have a 4R70W/AODE? Read!
Awesome article. I'll definately have to check that out AFTER I get my exhaust/4.10's/tb and other associated intake work done. Should make for an interesting ride lol.
How much is that torque converter? And would that be a good stall 3000? And how much does it usually cost to get it installed?
Its $900 something on www.tciauto.com
Its $720ish on www.summitracing.com for the TCI StreetFighter ------------------------------------------------------ Precision Industries also sells a converter (thx JD) , called the Stallion. "for an 01 Mustang with bolt-on's I would suggest around a 2600 to 2800 rpm stall speed." (this info coming from Jack with Precision Industries) The converter sells for $734.58 and comes with a 2 year warranty. Precision Industries 800-649-7866 So I'm guessing 3000+ would be recommended if your doing a camswap or have cams. |
I'm most likely going with Edge Racing's 3000-3200 www.edgeracingconverters.com
$565 you decide stall (2000-6500) I'm doing VT stg 1/2 cams, it should benefit. |
I'm getting mine install next week. I got the TCI "Breakaway" converter, 398 plus 325 for labor.
how do u know how much of a stall to get?
I have a 99. And I'm going to be doing most bolt-on's, not cams though. And eventually if I can get the money supercharge but not sure. What would you reccomend? |
ORIGINAL: Valek I'm getting mine install next week. I got the TCI "Breakaway" converter, 398 plus 325 for labor. http://www.tciauto.com/ford/ford_aod.htm "1994 & later Ford AODE" They only make a "Sat. Night Special" and "SteetFighter". |
