diablosport
diablosport
i'm about to order the gear package from rpm outlet with the 4.10 gears and the diablo sport and was wondering, if i needed to buy anything else for the tuner for when i go to dyno it.
RE: diablosport
no you dont need anything else it comes with a tune preloaded on the tuner read the instructions plugs right in under the steering wheel and do what it says very simple.... after gears install just change gear ratio to 4.09 and your speedo will be correct...if you want to run 93 octane for the extra HP then advance the timing while your at it with the tuner...
RE: diablosport
dude no you dont have to goto a dyno.... you just get the handheld you plug it in like the instruction say and load the **** onto your car computer... you dont need to go get a dyno till you have ALLLLLL your stuff done then they can do specific for your car tunes....the handheld is so that you dont waste money getting dyno's till all your stuff is done
RE: diablosport
honesty other then gears the advanced timing and tune was ONLY other mod i have noticed.... the car pulls much harder and sounds much better with the tune and advanced timing 10% specially WOT... ive been told that with 10% when idle that is like 11 degree advance but when wot you can see up to 26 degree advance b/c the tuner modifies it electronically which means 10% throughout the rpm's not like mechanical where its just 10degree advance.... get the handheld and even before you get gears installed put the tune on it and advance the timing to 10 and see if you dont notice nice gains...
t3000
05-10-2005 09:03 PM
