Comp Cams XE270AH
RE: Comp Cams XE270AH
i have a 2000 GT, i dont think they listed as non PI cams or not, its how much valve clearence you have to worry about, i had to choose from the .500 lift cams cause the .550 was too much
same for you if you have a stock bottom end you can only choose between comp cams 102100 102200 or 102300
102100--- SOHC-Stock replacement cam with more RV power. Better torque and power. Will work with stock computer.
102200--- SOHC-Mild Street performance, 3.23-3.55 gears. Good torque and power, will work with stock computer, noticeable idle.
102300--- SOHC-Hot street cam, 3.55-3.73 gears, 2000+ stall, computer upgrade recommended. Rough idle
the 274H .500 lift cams are the "non PI" cams offerd by comp. Personally I think they work pretty good Im not a big fan of some of the modular cams out there after seeing some real dyno #'s from folks in person.
ORIGINAL: yoteehunter
BTW, thats alot of cam dude, I hope ya have a aftermarket bottom end. Gonna lose some serious torque down low to make big numbers up top.
