2v or 4v
RE: 2v or 4v
If anything the 4v will have more rotating mass, but not much (two extra timing chains, two extra cams, 16 extra valves)... if they both have the same power, they will be close... a 4v engine just flows better.
RE: 2v or 4v
ORIGINAL: 00stang37
if you made 500rwhp on a 2v and 500rwhp on a 4v, what would be faster? does the 4v make it rev up faster or mainly let it make more power easier?
However, if you are comparing a 500 HP 2v in a GT and a 500 HP 4v in a cobra it will be the GT every time.
RE: 2v or 4v
ORIGINAL: 2000GT4.6
I would say the 4v if you are comparing them in the same cars, because the 4v will make more torque.
ORIGINAL: 00stang37
RE: 2v or 4v
ORIGINAL: Albizo66
Why so?
Why so?
but I think it would be pretty close, the Cobra's factory suspension setup is for the corners... and they have bigger brakes, ect (more unsprung and sprung weight)... I couldn't just give it to either.
RE: 2v or 4v
i didnt know that the timing chains & valves were considered rotating mass....
ORIGINAL: ShadowDrake
RE: 2v or 4v
ORIGINAL: 00stang37
