Which gives you more performance?
RE: Which gives you more performance?
The X Pipe will definitley sound better, and may even give you a couple horse over a straight pipe design...you have to have a connection to equal out the pressure...
Are you talking about not running a cross over in your exhaust? You really don't want to run straight pipes if that's what your talking about. That will resonate really bad.
wait...
Are you asking about, say, a catted X pipe verses an off road X pipe? What the hp difference between those is? If so, the catless will have a bit more, prolly not noticeable. If you have an emissions heavy state though you should get catted.
ORIGINAL: StriktlyGT
From what I read, its only ok for V6's to run straight pipes with no crossover, its due to the firing sequence of the V8's
ORIGINAL: AmericanRicer87
I'm wondering if having a Cat-less x pipe woul give you more or less performance than a straight pipe setup with no cats.
ok thats what i was wondering because who ever had my stang before me did the straight pipe thing, but it has a small like inch pipe that runs and is welded in between the two, no sure if thats just a brace or what not.
ORIGINAL: Stang9946
Catless X pipe will give you a little more hp.
