sub frame connectors
Old 04-13-2006, 01:58 PM
StockD15b
StockD15b's Avatar
Default sub frame connectors
hey guys, i plan on ordeing gears n drag radials in the next day or two. But id like to get the car prepaired for em. got a girdle on order as well. but im looking at subframe connectors n have a few question. 1. good,best,better brands. who you use/reccomend. 2. Standard or Full length, the pros n cons of the two.
Thanks in advance
StockD15b is offline
Old 04-13-2006, 01:59 PM
SOHCtimes2
SOHCtimes2's Avatar
Default RE: sub frame connectors
Maximum Motorsports I think is one of the prefered brands. Also if you're in socal i know a guy that does custom ones.
SOHCtimes2 is offline
Old 04-13-2006, 02:03 PM
rbstang
rbstang's Avatar
Blue Oval Performance SubFrame Connectors. $50 bucks... can beat that
Red
or
Black
The BEST subframes... probably Maximum Motorsports.. but the ones blueoval makes is same as rest of the subframe connectors out there... 14gauge steel... its all the same really. $50? cant beat that man. Dont waste your money/time with standard get full length bro.
rbstang is offline
Old 04-13-2006, 02:20 PM
StockD15b
StockD15b's Avatar
sweeet. thanks for the quick responses. whats the usural install price, or is it a DIY? also just wondering the pros n cons? if any.
Old 04-13-2006, 02:25 PM
Birdieman4
Birdieman4's Avatar
Get a mid to full length sub frame for best results. Make sure they are welded in, and not bolted. IMO, the best subframe out there is the Kenny Brown extreme matrix system, but and subframe mid to full length welded in place will do the trick.
Birdieman4 is offline
Old 04-13-2006, 02:27 PM
Fryguy22
Fryguy22's Avatar
If you know how to weld and have a welder then you can easily do it yourself. When I get mine me and my friend are renting a welder and are going to do it ourselves.
Fryguy22 is offline
Old 04-13-2006, 02:36 PM
Supergreen
Supergreen's Avatar
if you get subs go with full length and get them welded to the frame. you get the most responce when you weld it. your car will feel alittle different untill you get use to it.
Supergreen is offline
Old 04-13-2006, 02:40 PM
01BlueCobraVert
01BlueCobraVert's Avatar
1. Can you bolt them in and then get them welded?
2. Are there some that bolt in and others that only weld in?
3. Do you laways bolt and then weld?
Thanks
01BlueCobraVert is offline
Old 04-13-2006, 08:10 PM
rbstang
rbstang's Avatar
ORIGINAL: StockD15b
around here its about $40 a weld.. so $100 or so... pends where you live.
Pros - Chasis becomes stiffer and you can feel it coming off the line.
Cons - For maximum strength they need to be welded on.
rbstang is offline
Old 04-13-2006, 08:14 PM
Machwon
Machwon's Avatar
Kenny brown, maximum motorsports, and my personal favorite Hans racecraft : www.32valve.com
Machwon is offline
Quick Reply: sub frame connectors
