spark plugs
can someone tell me the best kind to get, and wut exactly they do other than just start your car, if they do anything?
RE: spark plugs
I use the autolite 764's and I have a 00GT
I will post a list of plugs from another thread. |
RE: spark plugs
ok cool, thanks! wut all do spark plugs do?
RE: spark plugs
http://forums.modulardepot.com/showthread.php?t=2218 I hope this helps
This list was originally started by ALLMTR2V on the corral and alot of people helped to get it right. I thought it would be a good addition to the MD! MOTORCRAFT PART# / HEAT RANGE AWSF-32C / stock heat range - copper plug AWSF-22C / 1 Heat range colder - copper plug AWSFA-12C / 2 Hea range cooler - copper plug AGSF-32C/ Recommended for FRPP heads(not sure on heat range) NGK PART# / HEAT RANGE TR-55/ 3951/ Stock Heat Range TR-6/ 4177/ 1 Step Colder BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps R5724-8 (PN - 7317) two and a half steps R5724-9 (PN - 7891) three steps R5724-10 (PN - 7993) four steps AUTOLITE PART# / HEAT RANGE 764s / Stock 103s / 1 heat range cooler AR94 / 2 heat range cooler AR93 / 3 heat range cooler AR92 / 4 heat range cooler CHAMPION PART# / HEAT RANGE YS-59C / -3 or -4 below stock heat range DENSO PART# / HEAT RANGE IT16 / stock heat IT20 / -1 heat range IT22 / -2 heat range IT24 / -3 heat range |
RE: spark plugs
I have a set of NKG V-power TR55 spark plugs... CHeeap but good plugs! =D
RE: spark plugs
After the air and fuel enters the chamber the piston comes up and compressed the gasses. at that time the COP sends a electric polce to the plug that makes it spark setting off a controled explosion in the chamber forcing the piston back down.
RE: spark plugs
i have denso IT24... 13 a plug but mine were free with exhaust
RE: spark plugs
Luckey you, how do you like them. They never have them when I go to change plugs. I will try them next but I realy like the autolites. too.
RE: spark plugs
about how much are these? and installation? should i do it myself or get some one else to do it for me?
RE: spark plugs
I ran those bosh 4's and those are crap, I would not run those in my lawn mower.
