wont start need to brainstorm
ok it cranks but it wont fireup. fuel pump is good, plugs are new, wires are fine, starter is new. i think it might be fuel related, but it started up fine the other day, so its not the pump im sure. would having the wrong cylinder plug wire in the wrong spot on the coilpack effect it from firing up? when trying to start it yesterday it made a loud crack sound towards the back, like a backfire. i need some ideas, just throw them at me. thanks
RE: wont start need to brainstorm
it stutters like its going to run, its pissing me off because it ran yesterday with the gas tank on the ground and without me jumping it. ill check the coil pack again, im thinking maybe the injectors arent spraying. they are 42#
Because you say it started recently...that is leading me away from fuel pressure. I could be wrong but I am betting on crossed wire. At least for you, I hope it is that simple.
dalefrancis88
09-11-2015 07:15 AM
