Help Installing Welds
I just got me a set of Weld Draglites, 6 inch fronts and 8 inch backs, with tires for $300. Need help installing fronts. They would not fit because of the brake caliper so i had to get 1/4 inch spacers and they still rubbed a little, so i had to grind down a very little spot on my caliper. After they were installed they rubbed but it wasnt the caliper. I took they wheel off and looked at the spacer and u could move it very slightly to the side. Its the kind u just put on the studs and put your wheel on after. I took them off and found a spot where they didnt move, and reinstalled, but it still made the same noise. I think these are just cheap spacers, or something. Maybe i installed them wrong i dont know. I need help if anyone has put welds on there GT. Any advice will help.
RE: Help Installing Welds
ORIGINAL: 93BlackNotch
Bogart makes rims that bolt right on.... They are light, and they look badass
Go with the hubcentric ones, maybe 1/2"....that should give you enough clearance since the 1/4" ones aren't enough.
Don't buy wheels if they don't fit.... That is a safety issue, they won't let you run at the track when they see spacers during tech inspection.... Next time do some research before you buy things....
