Need input on engine cleaning...
Ok my engine is decently clean... but not where i want it.. so what do you guys recomend to clean it with? methods of doing so? and whatever else you wanan throw at me?
thanks for the help guys..
RE: Need input on engine cleaning...
degreaser on a rag... Apply liberaly till rag is wet, apply elbow grease to what you want clean, go over it with a clean rag afterwards, cover coil packs (if applicable) and spray with hose. Go over with a clean rag one more time. Start her up to get the water off the belt, spray on some belt dressing on the underside of your belts. Let that sit for about a min, then start it up again. Good to go. Its my method (If your belt has never squeeked or is relatively new, skip belt dressing.. its not necessary.. I just despise squeeky belts, even if its just when you start up for the first few min..)
Results?
Results?
ORIGINAL: yellowcobra
lucky the guy before me did that good of a job. Now i'll just have to pay someone to do it.
