Running rich vs lean
RE: Running rich vs lean
running lean = sometimes more power,slightly increased MPG, drastically more combustion chamber/cylinder head heat and your engine will not last under this condition, you can see it by very white spark plug tips usually
running rich = a little less power, less MPG, fouled spark plugs, not as rough on your engine as running lean. This will show up as dark spark plug tips, usually coated with carbon
you want your mixture as close to stoich as possible
