Handheld tuner and emissions questions
If I get a handheld tuner do I need to reinstall the factory tune when I go for emissions testing...I am planning on getting an o/r x and swapping in my old h with cats when it comes time for testing...WIth the tuner can I just turn back on the 02 sensors and leave the tune on, or do I need to throw back the factory tune? Any help is appreciated...
RE: Handheld tuner and emissions questions
just remember if you set the tune back to stock to go in for the test you will fail b/c all the driving history will be erased. You will have to complete run cycles. i found that out the hard way
why do you guys bother swapping back and forth with cats and no cats, i mean do one or the other and leave it, its more of a hassle to put on/take off, then it is to gain the extra 1 horse, i dont get why you guys do it, plus if you dont have them on you can get in trouble if you get pulled over, i mean they can hear the difference between cats/no cats....why dont you just run cats with no muffs? that would make it louder...
Ryan
Ryan
cause no cats sounds different and whats the point of a catback if you dont use the mufflers. if its not a problem to switch you midpipe out for a day, then why not? i will be doing this when i get an o/r pipe cause i like the sound
its just not somehting you want to do with exhaust, once it is sealed up it wont be the same after you break the seal...you dont get a catback if you dont run muffs, you just take the stockers off, and put a pipe, call it good, why spend over $1000 for full exhuast when you can get it as good if not better sounding for like 50-100...im glad mine was all full exhaust with headers when i bought mine, hahah
Ryan
Ryan
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
