suspension
suspension
what would be considered a good suspension setup? sway bars, shocks and struts, and control arms. would that be it or what? i don't know a whole lot about suspension but i want the best.
RE: suspension
All of the above. If you are really serious about handling, it all starts with the springs. They lower your center of gravity and increase handling substantially. Change the shocks and struts at the same time since your suspension will be apart anyway. If you have the bucks, go with an all in one package such as those offered by Steeda. They are pricey but will save you bucks in the long run if you should end up buying all the same parts one at a time. Also, remember the complete kits are all "matched" components for best overall controlled handling characteristics. Steeda sells different "stage" handling packages. Check them out: www.steeda.com Click on Mustang parts and next suspension. Lots of goodies there. Good luck with your ride!
RE: suspension
upper and lower control arms by granetili from cool blue performance 160 bucks, MM Full Subframe connectors from Stang Suspension for 114 bucks, H&R Super Sport Lowering springs 225 bucks at stang suspension (plan on going with longtubes so dont want more then 1.5" drop), Tokico Shocks and Struts for 316 bucks at stang suspension, and use the coupon code: 38STANG for discount....
Matt's 95 Stang
10-05-2015 07:16 AM
