gauge install question
RE: gauge install question
That's the install document from AutoMeter -- and it's going to be very vague. There are MULTIPLE places to tap into power, and the part on the PCM is pretty specific. (there should be one connection for each side - driver and passenger o2) I would pick up a repair manual for a point of reference to make sure you hit the right connections, either from Ford or from Haynes.
Good luck with the install.
I did a write-up on it in the general tech section. https://mustangforums.com/m_1243280/mpage_2/key_/tm.htm
Wire the signal wire down under the car (where your shifter meets the tranny is a good place to slide the wire through) and splice into your signal wire on your o2 sensor. That's how mine was done and it works perfect...
ORIGINAL: xx9gt6xx
HIS S-197
08-10-2015 05:47 PM
