Stupid question here but kind of important.
RE: Stupid question here but kind of important.
Here in Kansas seeing as we have drastic weather [:@] I usually run with 5w-30 or even 10w-30 because of the hot summers and chilly as nuts winters....Plus Lucas stabalizer(sp)...I'm not having any problems with my Tropartic oil/Lucas synthetic blend....Filled it abit to much but thats it...
use 5w-20 like it says. your engine needs that weight oil because of tight tolerances between moving parts. heavier oil will not lubricate as well. ford didn't put 5w-20 on the filler cap for ****s and giggles.
ORIGINAL: miglet
maybe u should try changing ur oil filter too :O
I did change the oil filter. That is part of the normal oil change.
Yea, When I did my first oil change and saw the 5-20, I was like WTF, but after a little research, I found that it is actually kind of important to run the 5-20, I guess these motors do run very tight tolerances and thicker oils will not protect your motor as well, I would highly reccomend running 5-20 next time you change it, could mean the difference of a few thousand miles of engine life towards the end
AmericanMuscle4.6GT
11-10-2015 02:06 PM
