MSD Ignition 4.6L
Old 04-21-2006, 03:29 PM
Biltsy
Biltsy's Avatar
Default MSD Ignition 4.6L
Hi guys. Have any of you 4.6ers had any luck with adding the MSD box to your engines. Mine is stock right now, but I need to know what to add correctly.
Biltsy
Biltsy is offline
Old 04-21-2006, 03:36 PM
2VNA
2VNA's Avatar
Default RE: MSD Ignition 4.6L
hold on a second I have some info that you may want to look at.
2VNA is offline
Old 04-21-2006, 03:39 PM
2VNA
2VNA's Avatar
You can save a alot if you get in on this. and I know it's not on the MSD but someting you might want to look at.
here is the link
http://forums.modulardepot.com/showt...ight=group+buy
Granatelli - Micro Tech introduces another industry first with the Ford Modular Motor coil packs. This kit consists of eight 40,000 volt epoxy filled high temperature H.D. coils with the connector kit included. These coil packs provide near zero OHM resistance with up to 35% more power to the spark plugs. This upgrade will increase HP and is a must for any forced induction setup. Coil packs ahve a one-year limited warranty on the coil and limited lifetime warranty on the connectors.
2V
Retail - $529.95
Group Buy Price - $425.95
3V
Retail - $633.95
Group Buy Price - $449.95
Performance Coil on Plug Connector Kits
This is an industry first performance ignition upgrade for coil on plug and direct ignition. The OE boots and springs have numerous shortcomings, such as boot burn through and arching. The contact springs have resistance that limits power to the spark plug and may be completely stretched out of shape when changing plugs.
This kit features a 3/16" solid stainless steel core, a 500* silicone spark plug boot, and has unheard of zero ohms resistance.
2V
Retail - $99.95
Group Buy Price - $79.95
3v
Retail - 169.95
Group Buy Price - $129.95
4v
Retail - 107.85
Group Buy Price $85.95
Plug Wires for 96-98
Hard Core Series
These plug wires are an industry first. This wire set features a Solid Stainless Steel Core, an 8mm 500* silicone jacket, and has unheard of zero ohms resistance per foot. The best set of wires on the market today.
2V
Retail $99.95
Group Buy Price $74.95
4V
Retail $149.95
Group Buy Price $119.95
Pro-Street Series
Uses low ohm Packard stainless steel wire wound Mag wire. Uses 500* high temp silicone jacketing with reinforced fiberglass braid, a Kevlar reinforced core and high temp silicone boots.
2V
Retail $71.87
Group Buy Price $59.95
4V
Retail $119.95
Group Buy Price $99.95
H.0 Series
Competitively priced wire set that uses performance Packard double silicone wire. The core consists of strands of Kevlar impregnated with high conductive latex.
2V
Retail $59.95
Group Buy Price $49.95
4V
Retail $105.95
Group Buy Price $89.95
2VNA is offline
bradleyb
11-27-2015 07:50 PM
firehorse02
11-16-2015 11:28 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
jessicarabbit
09-25-2015 12:41 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: MSD Ignition 4.6L
